When you group two or more objects, they are treated as a single unit but retain their individual attributes. Grouping lets you apply the same formatting, properties, and other changes to all the objects within the group at the same time. In addition, grouping helps prevent accidental changes to the position of an object in relation to other objects. You can also create nested groups by grouping together existing groups.
Individual objects retain their attributes when they are grouped.
You can add objects to or remove objects from a group, and you can delete objects that are members of a group. You can also edit a single object in a group without ungrouping the objects. If you want to edit multiple objects in a group at the same time, you must first ungroup the objects. If a group contains nested groups, you can ungroup all objects in the nested groups simultaneously.
| To group objects |
1. |
Select the objects.
2. |
Click Arrange |
The status bar indicates that a group of objects is selected.
You can select objects from different layers and group them; however, after
objects are grouped, they reside on the same layer and are stacked on top of one
another.
You can create a nested group by selecting two or more groups of objects and
clicking Arrange |
You can also group objects by dragging an object in the Object manager
docker over another object. If the Object manager docker is not open, click
Window |
You can also group objects by clicking the Group button on the property bar.
| To add an object to a group |
In the Object manager docker, drag the object to the group.
If the Object manager docker is not open, click Window |
| To remove an object from a group |
In the Object manager docker, drag an object outside the group.
To delete an object in a group, select the object in the object list, and click Edit
| To edit an object in a group |
1. |
Click the Pick tool
2. |
Hold down Ctrl, and click an object in a group to select it.
3. |
Edit the object.
You can also select an object in a group by clicking the object in the Object
manager docker. If the Object manager docker is not open, click Window |
| To ungroup objects |
1. |
Select one or more groups.
2. |
Click Arrange, and click one of the following commands:
Ungroup — breaks a group into individual objects, or a nested group into
multiple groups
Ungroup all — breaks one or more groups into individual objects, including
objects within nested groups
Choosing Ungroup all also ungroups all nested groups. To preserve nested
groups, select Ungroup.
You can also ungroup objects by clicking the Ungroup button
You can also ungroup all nested groups within a group by clicking the
Ungroup all button
