The installation wizard makes it easy to install CorelDRAW Graphics Suite applications and components. You can choose a typical installation to quickly install the suite, or you can customize the installation by choosing different options.
You can also use the installation wizard to do the following:
modify the current installation by adding or deleting components
repair the current installation by reinstalling all application features
uninstall CorelDRAW Graphics Suite
Repairing an installation is helpful when you encounter problems in using the application, or when you suspect that the installation is corrupt. Before repairing an installation, try resetting the current workspace to the default settings by holding down F8 while starting the application.
To install CorelDRAW Graphics Suite applications | ![]() |
1. |
Close all applications, including all virus detection programs.
2. |
Insert the DVD in the DVD drive.
(Windows 7 and Windows Vista) If the installation wizard does not start automatically, click Start on the Windows taskbar, and type X:\autorun.exe in the search box, where X is the letter that corresponds to the DVD drive. |
(Windows XP) If the installation wizard does not start automatically, click Start on the Windows taskbar, and click Run. Type X:\autorun.exe, where X is the letter that corresponds to the DVD drive. |
3. |
Read the license agreement, and then enable the I accept the terms in the license
agreement check box.
4. |
Click Next.
5. |
Type your name in the User name text box.
6. |
Type your serial number in the Serial number text box.
The serial number is not case-sensitive, and the dashes are optional. |
7. |
Click Next.
8. |
Follow the installation wizard instructions for installing the software.
To modify or repair a CorelDRAW Graphics Suite installation | ![]() |
1. |
Close all applications.
2. |
On the Windows taskbar, click Start ![]() |
3. |
Do one of the following:
(Windows 7 and Windows Vista) Click Uninstall a program.
(Windows XP) Click Add or remove programs.
4. |
(Windows 7 and Windows Vista) Double-click CorelDRAW Graphics Suite on
the Uninstall or change a program page.
(Windows XP) In the Add or remove programs dialog box, choose
CorelDRAW Graphics Suite from the list, and click Change/Remove.
5. |
Follow the instructions that appear.
To uninstall CorelDRAW Graphics Suite | ![]() |
1. |
2. |
3. |
4. |
Enable the Remove option in the wizard that appears, and follow the instructions.
To completely uninstall the product by removing user files, such as presets, user-created fills, and customized files, enable the Remove user files check box. |
Any additional components and applications that you installed with the suite,
such as the CorelDRAW Graphics Suite X6 - Windows Shell Extension or
Microsoft Visual Studio Tools for Applications (VSTA), must be uninstalled
separately.
