PaintBrush (PCX)
The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file Back to Top
1.
Click File Import.
2.
Locate the folder in which the file is stored.
3.
Do one of the following:
(Windows 7 and Windows Vista) Choose PCX - PaintBrush (*.pcx) from the list box next to the File name box.
(Windows XP) Choose PCX - PaintBrush from the Files of type list box.
4.
Click the filename.
5.
Click Import.
6.
Click the drawing page.
To export a PaintBrush file Back to Top
1.
Click File Export.
2.
Locate the folder in which you want to save the file.
3.
Choose PCX - PaintBrush from the Save as type list box.
4.
Type a filename in the File name list box.
5.
Click Export.
6.
In the Convert to bitmap dialog box, adjust the width, height, resolution, color mode, or any of the other settings.
PaintBrush (PCX) technical notes Back to Top
Exporting a PCX file
Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or RGB color (24-bit).
Run-length encoding (RLE) compression is supported, and the maximum image size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes.
This file format is supported in CorelDRAW and Corel PHOTO-PAINT.
Importing a PCX file
PCX files can be imported if they conform to the following PCX specifications: 2.5, 2.8, and 3.0.
RLE compression is supported and the maximum image size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes. Files containing three color planes or more than four color planes cannot be imported.
