Preparing a print job for a print service provider
You can use the Collect for Output wizard to guide you through the process of sending a file to a print service provider. The wizard simplifies processes such as creating PDF and CDR files; gathering different pieces required for outputting an image; and copying the original image, embedded image files, and fonts.
You can print a drawing to a file, which lets the print service provider send the file directly to an output device. If you are unsure about which settings to choose, consult the print service provider.
For more information about commercial printing, see Working with a print service provider.
To use the Collect for Output wizard Back to Top
1.
Click File Collect for output.
2.
Enable one of the following options:
Automatically gather all files associated with the document
Choose a printing profile (.CSP) for gathering only specific files
3.
Follow the instructions in the Collect for output wizard.
The PDF file settings for the print service provider and the Prepress settings are identical. For information about the PDF Prepress style settings, see Exporting documents as PDF files.
To print to a file Back to Top
1.
Click File Print.
2.
Click the General tab.
3.
In the Destination area, enable the Print to file check box.
4.
Click the flyout arrow, and click one of the following commands:
For Mac — saves the drawing to be readable on a Macintosh computer
Single file — prints all pages in a document to a single file
Pages to separate files — prints each page to a separate file
Plates to separate files — prints each plate to a separate file
5.
Click Print.
6.
Choose one of the following from the Save as type list box:
Print file — saves the file as a PRN file
PostScript file — saves the file as a PS file
7.
Choose the folder where you want to save the file.
8.
Type a filename in the File name box.
9.
Click Save.
If you prefer not to prepare PostScript files, print service providers equipped with the application in which you created your work can take the original files (for example, CorelDRAW files) and apply the required prepress settings.
