Rotating and mirroring objects
CorelDRAW lets you rotate and create mirror images of objects. You can rotate an object by specifying horizontal and vertical coordinates. You can move the center of rotation to a specific ruler coordinate or to a point that is relative to the current position of the object.
Rotating objects around a single point
Mirroring an object flips it from left to right or top to bottom. By default, the mirror anchor point is in the center of the object.
Mirroring an object from top to bottom
To rotate an object Back to Top
1.
Select an object.
2.
In the toolbox, click the Free transform tool .
3.
Click the Free rotation button on the property bar.
4.
Type a value in the Angle of rotation box on the property bar.
You can also
Apply the rotation according to the object’s position rather than the x and y coordinates
Click the Relative to object button on the property bar.
Use rotation handles to rotate an object
Using the Pick tool, click the object twice to display the rotation handles. Drag a rotation handle clockwise or counterclockwise.
Rotate an object using the Transformation docker
Click Window Dockers Transformations Rotate.
You can also view and set the relative center of an object by clicking the object to display the rotation handles and dragging the relative center handle (circle with a dot in the middle) to a new position.
You can set the relative center of an object to its original position by enabling the Relative center check box in the Transformation docker and clicking the center option in the area below the check box.
You can also rotate an object by using the Transform toolbar. To open the toolbar, click Window Toolbars Transform.
To rotate an object around a ruler coordinate Back to Top
1.
Select an object.
2.
3.
Disable the Relative center check box.
4.
Type a value in the Angle box.
5.
Type values in any of the following Center boxes:
H — lets you specify the point on the horizontal ruler around which the object rotates
V — lets you specify the point on the vertical ruler around which the object rotates
6.
Press Enter.
To mirror an object Back to Top
1.
Select an object.
2.
Click Window Dockers Transformations Scale.
3.
In the Transformation docker, click one of the following buttons:
Horizontal mirror — lets you flip the object from left to right
Vertical mirror — lets you flip the object from top to bottom
If you want to flip the object on a specific anchor point, enable the check box that corresponds to the anchor point you want to set.
4.
Click Apply.
You can also mirror a selected object by holding down Ctrl and dragging a selection handle to the opposite side of the object.
You can also mirror a selected object by clicking the Mirror horizontally or the Mirror vertically button on the property bar.
