You can scan images directly from within the application by using the TWAIN driver of your scanner or Microsoft Windows Image Acquisition (WIA).
| To scan an image |
1. |
Click File |
Select WIA source — for a scanner that uses a WIA driver (available only on
Windows Vista and later versions)
Select TWAIN source— for a scanner that uses a TWAIN driver
A command appears disabled if a compatible WIA or TWAIN scanner driver is not installed. |
2. |
Choose a scanner from the dialog box that appears.
3. |
Click Select.
4. |
Click File |
5. |
Preview the image, and select the area that you want to scan.
WIA, in combination with some scanners, supports scanning of multiple areas to separate files. |
6. |
Click Scan.
