You can select individual, multiple, or all of the object’s nodes. Selecting multiple nodes lets you shape different parts of an object simultaneously. You can marquee select nodes by enclosing them with a rectangular marquee box, or by enclosing them with an irregularly shaped marquee box. Freehand marquee selection is useful when you want to select specific nodes in complex curves.
When a node is selected on curved segments, control handles are displayed. You can adjust the shape of the curved segments by moving the nodes and control handles.
Usually, a control handle is displayed as a solid blue arrowhead (left). When a control handle overlaps with a node, it is displayed as an unfilled blue arrowhead beside the node (right).
The Shape tool is the standard tool for moving nodes. You can also set an option to use the Pick and Bézier tools for selecting and moving nodes.
| To select a node |
1. |
In the toolbox, click the Shape
2. |
Select a curve object.
3. |
Click a node.
You can also select a node by using the Pick
To select all nodes on a selected curve, double-click the Shape tool.
| To move a node |
1. |
Select an object by using the Shape tool
2. |
Drag the node until you achieve the desired shape.
You can also move a node by using the Pick
