Before you can change an object, you must select it. You can select visible objects, objects that are hidden from view by other objects, and a single object in a group or a nested group. In addition, you can select objects in the order in which they were created, select all objects at once, and deselect objects.
A bounding box appears around a selected object, and an “X” appears at its center.
You can select a single object from a group.
You can marquee select objects by enclosing them with a selection area of rectangular or irregular shape.
Marquee selecting objects using a rectangular selection area (top) and a selection area of irregular shape (bottom)
You can create selection groups that let you select specific objects simultaneously without grouping them. Selection groups are associated with numbers from 0 to 9 and are saved with the document. When you press the number associated with a selection group, all objects in this group are selected. You can also select and zoom into all objects in a selection group at the same time. You can add objects to a selection group.
Usually, you select objects by using the Pick tool. By default, all objects are treated as filled so that you can select any unfilled object by clicking on its outline or the area surrounded by the outline. However, you can change this default behavior so that you can select unfilled objects only by clicking on their outlines. Changing the default behavior is useful when you work with line drawings and often need to select objects that appear beneath other objects.
| To select objects |
The status bar displays a description of each hidden object as you select it.
| To create a selection group |
1. |
Click the Pick tool
2. |
Press Ctrl + a number from 0 to 9.
The number you pressed is associated with the new selection group. |
| To deselect objects |
| To change how unfilled objects are selected |
1. |
Click Tools |
2. |
In the Workspace list of categories, click Toolbox |
3. |
Enable or disable the Treat all objects as filled check box.
Enabling the check box lets you select an unfilled object by clicking on its outline or the area enclosed by the outline; disabling the check box lets you select an unfilled object by clicking only on its outline. |
