Setting defaults for PowerClip frames
You can set the default behavior for dragging content to PowerClip frames, centering new content, and marking empty PowerClip frames from one central location — the new PowerClip Frame page in the Options dialog box.
For more information about PowerClip objects, see Creating PowerClip objects.
| To set default options for PowerClip frames |
1. |
Click Tools Options.
2. |
In the Workspace category, click PowerClip Frame.
3. |
Perform a task from the following table.
To
Do the following
Set the default behavior for dragging content to a PowerClip frame
In the Drag content inside PowerClip area, choose PowerClip with content or Empty PowerClip from the list box, and then choose one of the following options:
Ignore PowerClip frame — places the
content on top of the PowerClip frame
instead of inside
Add content to PowerClip frame
Replace existing content (available only
for PowerClip frames with content)
Set the default behavior for centering new content in a PowerClip frame
In the Auto-center new content area, choose one of the following options:
When content is completely outside
the frame — centers content only if it is
beyond the boundaries of the PowerClip
frame and will not be visible otherwise
Always — always centers new content
Never— turns off auto-centering
Mark empty PowerClip frames
Enable the Show lines in empty PowerClip frames check box, and choose one of the following options:
Always — displays lines in empty
PowerClip frames on screen and in printed
or exported documents
On screen only — displays lines in empty
PowerClip frames only on screen
