You can choose a preset or custom drawing scale so that distances in a drawing are proportionate to real-world distances. For example, you can specify that 1 inch in the drawing corresponds to 1 meter in the physical world. A preset drawing scale lets you set a typical scale, such as 1:2 or 1:10. A custom drawing scale lets you set any distance on the page to correspond to a real-world distance. For example, you can set a more accurate, precise scale that includes decimal numbers, such as 4.5 to 10.6.
Drawing scales are particularly useful if you are creating a technical or architectural drawing with dimension lines. For information about dimension lines, see Drawing connector and callout lines.
| To choose a preset drawing scale |
1. |
Click View |
2. |
In the Document list of categories, click Rulers.
3. |
Click Edit scale.
4. |
Choose a drawing scale from the Typical scales list box.
| To create a custom drawing scale |
1. |
Click View |
2. |
3. |
Click Edit scale.
4. |
Choose Custom from the Typical scales list box.
5. |
Specify the settings you want.
If the drawing scale is set to anything other than 1:1, the units on the vertical
ruler are the same as the units on the horizontal ruler.
