Setting up the baseline grid
The guides of the baseline grid run across the drawing page and follow the pattern of a ruled notebook. You can display or hide the baseline grid, turn snapping on or off, change the grid color, and set the line spacing. By default, the line spacing is 14 pt. All objects can snap to the baseline grid; only text frames can align to baseline grid. For more information, see Aligning text by using the baseline grid.
To display or hide the baseline grid Back to Top
Click View Grid Baseline grid.
A check mark beside the Baseline grid command indicates that the baseline grid is displayed.
To set baseline grid spacing and color Back to Top
1.
Click View Setup Grid and ruler setup.
2.
Perform a task from the following table.
To
Do the following
Set spacing
In the Baseline grid area, type a value in the Spacing box.
Set distance from top
Type a value in the Start from top box.
Setting this value to 0 makes the first line of the baseline grid overlap with the top edge of the drawing page.
Set color
Open the Color picker, and choose a color.
To turn baseline grid snapping on or off Back to Top
Click View Snap to Snap to baseline grid.
A check mark beside the Snap to baseline grid command indicates that snapping is turned on.
You can also click View Setup Grid and ruler setup and enable or disable the Snap to grid check box in the Baseline grid area.
