CorelDRAW lets you shape objects, including lines, artistic text, and paragraph text frames by applying envelopes to them. Envelopes are made of multiple nodes that you can move to shape the envelope and, as a result, change the shape of the object. You can apply a basic envelope that conforms to the shape of an object, or you can also apply a preset envelope. After you apply an envelope, you can edit it or add a new envelope to continue changing the object’s shape. CorelDRAW also lets you copy and remove envelopes.
You can edit an envelope by adding and positioning its nodes. Adding nodes gives you more control over the shape of the object contained in the envelope. CorelDRAW also lets you delete nodes, move multiple nodes simultaneously, change nodes from one type to another, and change a segment of an envelope to a line or curve. For more information about the different types of nodes, see Using curve objects.
You can also change the mapping mode of an envelope to specify how the object fits to the envelope. For example, you can stretch an object to fit the basic dimensions of the envelope, and then apply the horizontal mapping mode to compress it horizontally so that it fits the shape of the envelope.
| To apply an envelope |
1. |
Select an object.
2. |
In the toolbox, click the Envelope tool
3. |
On the property bar, click one of the following buttons:
Straight line mode
Single-arc mode
Double-arc mode
Unconstrained mode
4. |
Click the object.
5. |
Drag the nodes to shape the envelope.
If you want to reset the envelope, press Esc before releasing the mouse. |
You can prevent the object’s straight lines from being converted to curves by
enabling the Keep lines button
| To copy an envelope |
1. |
2. |
Click Effects |
3. |
Select the object from which you want to copy the envelope.
You can also copy an envelope by selecting an object, clicking the Copy
envelope properties button on the property bar, and selecting an object with
the envelope you want to copy.
You can also use the Eyedropper tool
| To edit the nodes and segments of an envelope |
1. |
2. |
3. |
Double-click the envelope to add a node or double-click a node to delete it.
| To change the mapping mode |
1. |
2. |
3. |
On the property bar, choose one of the following from the Mapping mode list box:
Horizontal — stretches the object to fit the basic dimensions of the envelope
and then compresses the object horizontally to fit the shape of the envelope
Original — maps the corner handles of the object’s selection box to the
envelope’s corner nodes. The other nodes are mapped linearly along the edge of
the object’s selection box.
Putty — maps the corner handles of the object’s selection box to the envelope
corner nodes
Vertical — stretches the object to fit the basic dimensions of the envelope and
then compresses the object vertically to fit the shape of the envelope
4. |
Drag the nodes or the control handles.
The mapping mode of paragraph text frames cannot be changed after an
envelope is applied.
