Skewing and stretching objects
You can skew and stretch objects in CorelDRAW. When you skew an object, you specify the degree by which you want to slant the object. Stretching changes an object’s vertical and horizontal dimensions non proportionally.
CorelDRAW also lets you change the skew and sizing anchor point of an object from its default center position.
Skewing an object horizontally
Stretching an object horizontally
To skew an object Back to Top
1.
Select an object.
2.
Do one of the following:
In the toolbox, and click the Free transform tool .
Click Window Toolbars Transform.
3.
Click the Free skew button on the property bar.
4.
Type values in the Skew angle boxes on the property bar to specify the number of degrees by which you want to skew the object horizontally or vertically.
If you want to apply the scaling according to the object’s position rather than the x and y coordinates, click the Relative to object button on the property bar.
You can also skew an object interactively by dragging one of its skew handles . If the skew handles are not displayed, click the selected object again, and point to the middle handles.
You can also access skewing options from the Transformation docker by clicking Arrange Transformations Skew.
To stretch an object Back to Top
1.
Select an object.
2.
Click Arrange Transformations Size.
3.
Disable the Proportional check box.
4.
In the Transformations docker, type a value in the following boxes:
H — lets you specify the width of a selected object
V — lets you specify the height of a selected object
5.
Click Apply.
The new values that you enter to stretch an object are the basis for a new ratio of the horizontal and vertical dimensions of the object. When you enable the Proportional check box, any resizing of the object is based on this new ratio. To revert the object to its original one-to-one proportions before transforming it again, you must enable the Proportional check box, and then retype the original values.
You can change object dimensions proportionally by enabling the Proportional check box, typing a value in either the H or V box, and pressing Enter.
You can also stretch an object from its center by pressing Shift and dragging a corner selection handle.
You can also stretch an object in increments of 100% by pressing Ctrl, and dragging a corner selection handle.
