Using QuickCorrect
QuickCorrect automatically corrects misspelled words and capitalization errors. You can customize QuickCorrect by specifying which types of errors you want to correct automatically.
In CorelDRAW, the quotation marks that are applied to text vary according to the language that you have selected. You can further customize the quotation marks for different languages by using QuickCorrect. For example, you can change the style of double, single, and straight quotation marks for a language.
Adding words to QuickCorrect lets you replace words and abbreviations that you often mistype. The next time you type the misspelled word, QuickCorrect corrects the word automatically. You can use this feature to create shortcuts to frequently used words and phrases. For example, you can store the phrase “for your information” under the abbreviation “FYI” so that each time you type “FYI” followed by a space, it is replaced with the phrase.
You can have QuickCorrect add corrections made with the spelling checker to its word list so that the next time you misspell the word the same way, it is automatically corrected.
You can also undo a QuickCorrect correction.
To customize QuickCorrect Back to Top
1.
Click Text Writing tools QuickCorrect.
2.
Enable any of the following check boxes:
Capitalize first letter of sentences
Correct two initial, consecutive capitals
Capitalize names of days
Automatic hyperlink
Replace text while typing
The Correct two initial, consecutive capitals option doesn’t make a change when a capital letter is followed by a space or period, or if a word contains other capital letters.
Instead of enabling the Capitalize first letter of sentences check box, you can change the text case to sentence case. For more information, see To change the text case.
To customize quotation marks for different languages Back to Top
1.
2.
Choose a language from the Language list box.
3.
Perform a task from the following table.
To
Do the following
Change straight quotation marks to typographic (“curly”) quotation marks
Enable the Change straight quotes to typographic quotes check box.
Insert straight quotation marks when the quotation mark follows a number
Enable the Use straight quotation marks after numbers check box.
Change the appearance of single quotation marks
Choose a quotation mark style from the Open and Close list boxes, or type a character in each of the boxes.
Change the appearance of double quotation marks
Straight quotation marks are sometimes used to represent feet ( ' ) and inches ( " ).
To add words to QuickCorrect Back to Top
1.
2.
Enable the Replace text while typing check box.
3.
In the Replace box, type the text to be replaced.
4.
Type the replacement text in the With box.
5.
Click Add.
You can use this feature to create shortcuts to frequently used words and phrases. Type the abbreviation in the Replace box, and the word or phrase in the With box.
To add spelling corrections to QuickCorrect Back to Top
1.
Click Tools Options.
2.
In the Workspace list of categories, double-click Text, and click Spelling.
3.
Enable the Add corrections to QuickCorrect check box.
To undo a QuickCorrect correction Back to Top
Click Edit Undo QuickCorrect.
