There are a number of tasks that are common to all types of fills. You can choose a default fill color so that every object that you add to a drawing has the same fill. You can also remove a fill, copy it to another object, or use it to fill an area surrounded by an open curve.
| To choose a default fill color |
1. |
Click a blank area on the drawing page to deselect all objects.
2. |
In the toolbox, click the Uniform fill button
3. |
In the Change document defaults dialog box, enable the check boxes for the
types of objects whose default fill you want to change.
4. |
In the Uniform fill dialog box, specify any fill settings.
You can also change the default fill color by editing the default style sets in the
Styles docker. For more information, see Managing default object properties.
| To remove a fill |
1. |
Select an object.
2. |
Click Edit |
3. |
In the Objects properties docker, click the No fill button
You can also remove a fill by clicking the Fill flyout in the toolbox, and then
clicking the No fill button
| To copy a fill to another object |
1. |
Using the Pick tool
2. |
With the right mouse button, drag the first object over the destination object, to
which you want to apply the fill.
A blue outline of the first object follows the pointer to the destination object. |
3. |
When the pointer changes to a crosshair pointer
You can also use the Attributes eyedropper
You can also sample the color of an existing object and apply the sampled color
to another object as a uniform fill. For more information, see To sample a color.
| To show fills in open curves |
1. |
Click Tools |
2. |
In the list of categories, double-click Document, and click General.
3. |
Enable the Fill open curves check box.
