Symbols
CorelDRAW lets you create objects and save them as symbols. Symbols are defined once and can be referenced many times in a drawing. Each time you insert a symbol into a drawing, you create an instance of the symbol. Symbol definitions, as well as information about instances, are stored in a symbol manager, which is part of the CorelDRAW (CDR) file. Using symbols for objects that appear many times in a drawing helps to reduce file size.
In this section, you’ll learn about
Create, edit, and delete symbols
Use symbols in drawings
Share symbols between drawings
Symbol collections and libraries
For information about modifying symbol instances and about unsupported object types, see Reference: Symbols.
For information about working with special characters in text, see Embed graphics.
