This section provides a sample of the CGM data that you can apply to objects . It is divided into three parts:
When you choose an event as the type, only one or more Active CGM commands can function as the value.
When you choose an action as the type, any of the following can function as the value:
Sample of WebCGM commands
button1press
Description: Triggers when you click any of the members of the group.
Value: WebCGM_button1press , or any of the WebCGM actions
content
Description: Allows you to declare the first priority when searching the text content of a ‘para’ APS.
cursorenter
Description: Triggers when the pointer moves within two pixels of any of the members of the group.
Value: WebCGM_cursorenter , or any of the WebCGM actions
cursorexit
Description: Triggers when the pointer moves off all members of the group.
Value: WebCGM_cursorexit , or any of the WebCGM actions.
hover
Description: Triggers when the pointer moves over any member of the group.
Value: any of the WebCGM actions
linkuri
Description: Loads a file in the target window as specified by the URI.
Value: either one or three strings entered by user input
_blank — viewer loads the content in a new window
_self — viewer loads the content in the same window
_parent — viewer loads the content in the immediate frameset parent of the active window
_top — viewer loads the content in the full original window
name
Value: entered by user inputExample: "Corel Designer Group"
region
Description: Provides an optional spatial region, associated with a graphic object, allowing the user to pick operations for the object. Simple regions of type rectangle, ellipse, polygon, and continuous polybezier can be defined.
screentip
Description: Causes the value to be displayed as a screen-tip when the pointer is positioned over the group.
Value: entered by user input as a single string that is associated with a graphic object or a groupExample: "This is a screentip"
viewcontext
Description: Lets you specify the initial view of an object when you position the pointer over the graphic object that contains this attribute.
The value of the viewcontext specifies the two corner points of the viewport rectangle as (x1,y1) (x2,y2), where x1, y1 is the top-right point of the viewport rectangle and x2, y2 is the bottom-left point of the viewport rectangle. Example: -925688030 586990613 -799207691 509452731
WebCGM_button1press
Description: Erases all usertip message boxes in the target window.Example: ‘eraseusertip;execute -extension "linkuri"’
Value: eraseusertip;execute -ext
WebCGM_cursorenter
Description: Displays the specified usertip.Example: ‘displayusertip -tip "<This is a screentip>"’
WebCGM_cursorexit
Sample of ActiveCGM commands
@ML_button1press
@ML_button1release
@ML_cursorenter
@ML_cursorexit
Description: Changes the group color to its original color.
@ML_ToInvisible
@ML_ToNative
Value: changegroup -co native
@ML_ToRed
@ML_ToVisible
button1press
Value: PressButton1 , or any of the WebCGM or ActiveCGM actions
button1release
Description: Triggers when you release the left mouse button while the pointer is positioned over any of the members of the group.
Value: ReleaseButton1 , or any of the WebCGM or ActiveCGM actions
cursorenter
Value: ToRed , or any of the WebCGM or ActiveCGM actions
cursorexit
Value: ToNative , or any of the WebCGM or ActiveCGM actions
description
Value: entered by user inputExample: "product description"
Sample of WebCGM S1000D commands
desc
linkuri
region
screentip
viewcontext
This site works best with JavaScript enabled
