HTML files are plain-text (also known as ASCII) files that can be created using any text editor, including SimpleText and TextEdit. HTML files are intended for display on a web browser.
You can import HTML files to edit text and add web objects, bookmarks, and hyperlinks.
To import an HTML file |
1 . | Click File ![]() |
2 . | Locate the folder in which the file is stored. |
3 . | Choose HTM - HyperText Markup Language (*.htm) from the list box next to the File name box. |
4 . | Click the filename. |
5 . | Click Import. |
6 . | In the Use default text colors area, enable one of the following options: |
• | Yes — uses the default color for text and for visited, unvisited, and active links, ignoring the colors specified in the HTML file |
• | No — uses the colors specified in the HTML file |
7 . | Click the drawing page. |
HTML technical notes |
• | The HTML import filter extracts editable information from a web document and brings objects into Corel DESIGNER in a manner similar to the original layout. |
• | Imported HTML files that exceed the boundaries of the drawing page continue down the workspace without a page break. |
