Before you assign project data to objects in a drawing, you need to know what information you want to display. By default, Corel DESIGNER creates multiple data fields including: Name, Cost, and Comments. These fields can be edited or deleted as required.
If you require custom fields, you can define their formats using four basic field formats: General, Date/time, Linear/angular, and Numeric. Each of these formats provides a series of common settings. If the preset formats in Corel DESIGNER don’t provide the information you want in your data summary, you can create your own custom formats using the variables available for the format type you’re using. The field format you select is used for all objects in the active drawing.
