A spare parts page contains a technical illustration with callouts and a table that lists the available parts and relevant part information. The steps to create interactive SVG files for online spare parts pages in Corel DESIGNER are outlined below, and detailed in the procedure that follows.
First, create a new document, and import the file that contains the illustration as a linked file. For more information about linked files, see "To import an externally linked file" on page 3.
Then, import the Excel Workbook (XLS or XLSX) or Comma-separated Values (CSV) file that contains information about the spare parts. Format the table text and header rows as needed. For more information, see "Format tables and cells" on page 6.
You can sync the linked illustration or table with their sources at any time; however, any changes that you have made to the linked objects in the current project will be lost. You can also break the link between the linked and source files and edit them independently of each other.
Next, assign data to the callouts in the illustration, the objects identified by the callouts as well as the rows in the table. When you assign the same interactive-id and mouseover effect to a callout, an object and a table row, they all change when you point to one of them in the exported file. For more information, see "Apply InteractiveSVG data to objects" on page 10.
Finally, export the Corel DESIGNER document to SVG.
An example of an interactive SVG graphic that can be used on a spare parts page. Point to a callout or a row in a table to see the outline change its width and color.
To export multiple pages to interactive SVG files, use the Export docker to export all pages at once by using the same settings. For more information, see Export objects and pages.
