There are three types of pattern transparency:
Bitmap pattern transparency — a color picture composed of patterns of light and dark or differently colored pixels in a rectangular array. |
Corel DESIGNER provides a collection of vector and bitmap patterns that you can access. You can browse the available patterns, search by keyword, mark patterns as favorites, vote for patterns that you like, or copy patterns from the Content Exchange to your personal library. For more information, see Managing fills and transparencies.
You can also create your own patterns. For example, you can create patterns from areas of the workspace or images that you import. Vector and bitmap patterns are made up of smaller units called tiles. Depending on the size of the object, the fill may consist of one or more tiles. The pattern is created by repeating the tile to fill up the object. You can create a new pattern by selecting an area of the workspace to use as a tile, or by using an imported image as a tile source.
After you create a pattern transparency, you can save it for future use or share it with other users on the Content Exchange. For more information, see Saving and sharing fills and transparencies.
You can modify pattern transparencies to suit your needs.
2 . |
Click Edit Property manager. |
3 . |
In the Transparency area of the Property manager docker, click one of the following buttons: |
4 . |
Open the Transparency picker, and click a thumbnail. |
5 . |
Click the Apply button in the pop-up window that appears. |
To apply the transparency only to the fill or the outline of the object, click the Fill button
or the Outline button
You can also click the Transparency tool
in the toolbox and use the controls on the property bar.
2 . |
3 . |
Click the Mirror tiles horizontally  or the Mirror tiles vertically  button.
In the Seamless area, click the Radial button  , or click the Linear button and move the slider.
Enable the Edge match check box, and move the slider.
Enable the Brightness check box, and move the slider.
Enable the Luminance check box, and move the slider.
Enable the Color check box, and move the slider.
Type values in the Transparency width and Transparency height boxes.
Click the Row offset  or the Column offset button  , and type a value in the % of tile box.
Enable the Transform with object check box.
You can also change the size of pattern tiles by clicking the Interactive fill tools button in the toolbox, clicking the Transparency tool
, selecting an object, and using the controls on the property bar.
You can also skew or rotate tiles by clicking the Interactive fill tools button in the toolbox, clicking the Transparency tool
, selecting an object, and dragging the skewing or rotation handles to change the appearance of the pattern.
2 . |
3 . |
In the Transparency area of the Property manager docker, click the Two-color pattern transparency button . |
To modify the pattern, click the Edit transparency button
, and specify the settings you want.
