You can load photos from digital cameras and scan images in Corel DESIGNER.
Corel DESIGNER supports scanners that use Microsoft Windows Image Acquisition (WIA), which provides a standard interface for loading images. If your scanner does not support WIA, you can use the TWAIN driver of your scanner for loading images. TWAIN is supported by both the 32-bit and 64-bit versions of Corel DESIGNER The software interfaces and options vary. For information about using the software associated with your scanner or digital camera, see the manufacturer’s documentation.
| To load photos from a digital camera |
1. |
Connect a digital camera to your computer.
2. |
Click File |
3. |
Choose a digital camera from the Sources box.
4. |
Click File |
5. |
Choose the images that you want to load from the dialog box that appears.
You are presented with the digital camera’s TWAIN driver interface for loading images. Options vary, depending on the digital camera. |
6. |
Click Get pictures.
On your digital camera’s interface, this button may have a different name. |
To load additional photos during the same session, click File |
If your digital camera does not have a TWAIN driver, you can still open photos
in Corel DESIGNER by clicking File |
| To scan images |
1. |
Click File |
Select WIA source — for a scanner that uses a WIA driver (available only on
Windows XP and later versions)
Select TWAIN source— for a scanner that uses a TWAIN driver
A command appears disabled if a compatible WIA or TWAIN scanner driver is not installed. |
2. |
Choose a scanner from the dialog box that appears.
3. |
Click Select.
4. |
Click File |
5. |
Preview the image, and select the area that you want to scan.
WIA, in combination with some scanners, supports scanning of multiple areas to separate files. |
6. |
Click Scan.
On your scanner’s interface, this button may have a different name, such as OK or Send. |
The WIA interface is available only for the Windows XP and later versions.
To scan additional images during the same session, click File |
