Arrowheads let you enhance the starting points and endpoints of lines and curves. You can specify the attributes of an arrowhead with precision. For example, you can define the exact size of an arrowhead as well as offset or rotate the arrowhead by a precise amount. You can also flip arrowheads vertically and horizontally. You can save your specified attributes as arrowhead presets for later use.
Arrowhead in its original form (1), resized (2), with offset of 60% along the x-axis (3), flipped horizontally (4), and rotated at 90 degrees (5).
You can edit existing arrowhead presets, and you can create an arrowhead preset based on an existing one. You can also create an arrowhead preset based on an object such as a curve or a closed shape. When you no longer need an arrowhead preset, you can delete it.
| To add an arrowhead |
1. |
Select a line or curve.
2. |
On the property bar, click the Outline pen button
3. |
In the Arrowheads area of the dialog box, open the Start arrowhead or End
arrowhead picker, and click a shape.
You can also
Switch arrowheads from one end of a line or curve to another
Click Options, and choose Swap.
Remove an arrowhead from a line or curve
Click Options, and choose None.
You can also add an arrowhead by using the Start arrowhead or End
arrowhead picker on the property bar.
| To specify the arrowhead attributes of a line or curve |
1. |
Using the Pick tool
2. |
If you want the start and end arrowheads to have the same size, offset, rotation angle, and orientation, enable the Share attributes check box in the Arrowheads area of the Outline pen dialog box. |
3. |
In the Arrowheads area of the Outline pen dialog box, click Options below the
Start arrowhead or End arrowhead picker, and click Attributes.
4. |
In the Arrowhead attributes dialog box, perform any of the tasks in the following
table.
Specifying the attributes of an arrowhead does not change the arrowhead preset
that was applied.
| To edit an arrowhead preset |
1. |
Using the Pick tool
2. |
3. |
In the Arrowheads area of the Outline pen dialog box, click Options, and choose
Edit.
4. |
In the Arrowhead attributes dialog box, specify the attributes you want.
For information about the attributes you can specify, see To specify the arrowhead attributes of a line or curve. |
You can create an arrowhead preset that is based on an existing preset. In the
New. Then, specify the attributes you want in the Arrowhead attributes
dialog box, and type a preset name in the Save arrowhead area.
To delete an arrowhead preset, select the preset from the Start or End
arrowhead picker in the Outline pen dialog box, click Options, and choose
Delete.
| To create an arrowhead preset from an object |
1. |
Select an object to use as an arrowhead.
2. |
Click Tools |
3. |
In the Create arrowhead dialog box, type a value in the Length box or Width
box.
If you want to create a nonproportional arrowhead, disable the Proportional check box, and type values in both the Length and Width boxes. |
