You can use bulleted lists to format information. You can wrap text around bullets, or you can offset a bullet from text to create a hanging indent. Corel DESIGNER lets you customize bullets by changing their size, position, and distance from text. You can also change the spacing between items in a bulleted list. For more information, see To adjust interline spacing.
Three paragraphs (left) were converted into a bulleted list (right)
You can remove a bullet without deleting the text.
| To add bullets |
1. |
Using the Text tool
If the Property manager docker is not open, click Window |
2. |
In the Property manager docker, click the Paragraph button
3. |
In the Paragraph area of the Property manager docker, click the arrow button
4. |
Enable the Bullets check box.
5. |
Click the Bullet settings button.
6. |
In the Bullets dialog box, perform a task from the following table.
To
Do the following
Preview text with bullets
Enable the Preview check box.
Choose a font
In the Appearance area, choose a font from the Font list box.
Choose a symbol
Open the Symbol picker, and click a symbol.
Set a bullet size
Type a value in the Size box.
Adjust the bullet position
Type a value in the Baseline shift box.
Set the distance from the text frame
In the Spacing area, type a value in the Text frame to bullet box.
Set the distance between the bullet and the text
Type a value in the Bullet to text box.
Bullets are inserted at the beginning of each new line that is preceded by a
return.
You can adjust the spacing in between bullets by increasing or decreasing the
space before and after a paragraph. For more information, see To adjust the
spacing between paragraphs.
