Corel DESIGNER lets you add pages to a drawing or duplicate existing pages. You can also rename pages and delete a single page or an entire range of pages. You can move objects from one page to another.
When you duplicate a page, you can choose to copy only the layer structure of the page or to copy the layers and all the objects they contain. For more information about layers, see Working with layers.
You can use the Page Sorter view to manage pages while viewing the page contents. The Page Sorter view lets you change the order of pages as well as copy, add, rename, and delete pages.
To add a page |
1. |
Click Layout Insert page.
2. |
In the Pages area, type the number of pages you want to add in the Number of
pages box.
3. |
To place the new page before or after the current page, enable one of the following
options:
Before
After
If you want to insert a page before or after a page other than the current page, type the page number in the Existing page box. |
You can also insert a page before or after the current page by clicking one of
the Add page buttons in the document navigator.
You can also add a page by right-clicking a page tab in the document navigator
and clicking Insert page after or Insert page before.
To duplicate a page |
1. |
In the Object manager docker, click the name of the page that you want to
duplicate.
If the Object manager docker is not open, click Window Object manager. |
2. |
Click Layout Duplicate page.
3. |
In the Insert new page area of the Duplicate page dialog box, choose one of the
following options:
Before selected page
After selected page
4. |
At the bottom of the dialog box, choose one of the following options:
Copy layer(s) only — lets you duplicate the layer structure without copying the
contents of the layers
Copy layer(s) and their contents — lets you duplicate the layers and all their
contents
You can also duplicate a page by right-clicking a page name and choosing
Duplicate page.
To rename a page |
1. |
Click Layout Rename page.
2. |
Type the name of the page in the Page name box.
You can also rename a page in the Object manager docker by clicking the
page name twice and typing a new name. To access the Object manager
docker, click Window Object manager.
To delete a page |
1. |
Click Layout Delete page.
2. |
In the Delete page dialog box, type the number of the page that you want to
delete.
You can delete a range of pages by enabling the Through to page check box
and typing the number of the last page to delete in the Through to page box.
To change the order of pages |
Drag the page tabs in the document navigator.
To move an object to another page |
1. |
Drag the object over the appropriate page tab in the document navigator.
The destination page appears in the drawing window. |
2. |
Without releasing the mouse button, drag to position the object on the page.
You can also move an object to another page by dragging the object name in
the Object manager docker over a layer name on the destination page.
To manage pages while viewing their contents |
1. |
Click View Page sorter view.
2. |
Perform a task from the following table.
You can also copy a page by right-clicking the page and choosing Duplicate
page.
