You can also set a hotspot that follows the outline of the object, or fills the object’s bounding box. Corel DESIGNER applies a crosshatch pattern to an object containing a link. You can change the color of the crosshatch pattern as well as its background fill. In addition, you can add alternate text to objects for text-only browsers or screen readers.
To set a hotspot |
1. |
Click Window Property manager.
2. |
Click the Internet button
3. |
Choose Link from the Behavior list box, and type a Web address in the URL box.
4. |
In the Define hotspot using area, click one of the following buttons:
Shape — defines the hotspot using the object’s shape
Bounds — defines the hotspot using the object’s bounding box
5. |
Open the Cross-hatch color picker
, and click a color.
6. |
Open the Background color picker
If you choose a hyperlinked object first and then change the crosshatch and
background hotspot colors, the change applies to the selected object only.
To add alternate text to an object |
1. |
2. |
3. |
Type the alternate text in the ALT comments text box.
