You can add twirl effects to objects. You can set the radius, speed, and direction of the twirl effects, and you can use the pressure of your digital pen to change the intensity of the twirl effect.
Adding a twirl effect
To add a twirl effect to an object |
1. |
Select a curve object using Pick tool
2. |
Click the Shape tools button in the toolbox, and click the Twirl tool
3. |
Click the edge of the object, and hold down the mouse button until the twirl is the
size you want.
To position and reshape the twirl, you can drag while holding down the mouse button. |
