The Image Adjustment Lab lets you correct the color and tone of most photos quickly and easily. You can access the Image Adjustment Lab by clicking Bitmaps Image Adjustment Lab.
1. Rotation tools
5. Select white point
9. Sliders
2. Pan tool
6. Select black point
10. Hint for current tool
3. Zoom tools
7. Undo, Redo, and Reset
11. Histogram
4. Preview Modes
8. Snapshots
The Image Adjustment Lab consists of automatic and manual controls, which are organized in a logical order for image correction. By starting in the upper-right corner and working your way down, you can select only the controls you need to correct the problems specific to your image. It is best to crop or retouch any areas of the image before beginning the color and tone corrections.
When you work in the Image Adjustment Lab, you can take advantage of the following features:
Create snapshot — You can capture the corrected version of an image in a
“snapshot” at any time. Thumbnails of the snapshots appear in a window below the
image. Snapshots make it easy to compare different corrected versions of the image
so you can choose the best one.
Undo, Redo, and Reset to original — Image correction can be a trial-and-error
process, so the ability to undo and redo corrections is important. The Reset to
original command lets you clear all corrections so that you can start again.
You can begin by using the automatic correction controls:
Auto adjust — automatically corrects the contrast and color in an image by
detecting the lightest and darkest areas and adjusting the tonal range for each color
channel. In some cases, this control may be all you need to improve an image. In
other cases, you can undo the changes and proceed with more precise controls.
Select white point tool — automatically adjusts the contrast in an image
according to the white point that you set. For example, you can brighten an image
that is too dark by using the Select white point tool.
Select black point tool — automatically adjusts the contrast in an image
according to the black point that you set. For example, you can darken an image
that is too light by using the Select black point tool.
After using the automatic controls, you can correct color casts in your image. Color casts are typically caused by the lighting conditions when a photo is taken, and they can be influenced by the processor in your digital camera or scanner.
Temperature slider — lets you correct color casts by “warming” or “cooling” the
color in an image to compensate for the lighting conditions at the time the photo
was taken. For example, to correct a yellow color cast caused by taking a photo
indoors in dim incandescent lighting, you can move the slider toward the blue end
to increase the temperature values (based on degrees Kelvin). Lower values
correspond to low lighting conditions, such as candlelight or light from an
incandescent light bulb; these conditions cause an orange cast. Higher values
correspond to intense lighting conditions, such as sunlight; these conditions cause a
blue cast.
Tint slider — lets you correct color casts by adjusting the green or magenta in an
image. You can add green by moving the slider to the right; you can add magenta
by moving the slider to the left. Moving the Tint slider after using the
Temperature slider lets you fine-tune an image.
Saturation slider — lets you adjust the vividness of colors. For example, by moving
the slider to the right, you can increase the vividness of a blue sky in an image. By
moving the slider to the left, you can reduce the vividness of colors. You can create
a black-and-white photo effect by moving the slider all the way to the left, so that
all color in the image is removed.
Correction of a color cast. The image on the right is the corrected version.
You can brighten, darken, or improve the contrast in an entire image by using the following controls:
Brightness slider — lets you brighten or darken an entire image. This control can
correct exposure problems caused by too much light (overexposure) or too little
light (underexposure) at the time the photo was taken. If you want to lighten or
darken specific areas of an image, you can use the Highlights, Shadows, and
Midtones sliders. Adjustment made by the Brightness slider is nonlinear, so the
current white point and black point values are not affected.
Contrast slider — increases or decreases the difference in tone between the dark
and light areas of an image. Moving the slider to the right makes the light areas
lighter and the dark areas darker. For example, if the image has a dull, gray tone,
you can sharpen the detail by increasing the contrast.
Adjusting the brightness and contrast of an image can reveal more image detail.
You can brighten or darken specific areas of an image. In many cases, the position or strength of the lighting at the time a photo is taken causes some areas to appear too dark and other areas to appear too light.
Highlights slider — lets you adjust brightness in the lightest areas of an image.
For example, if you take a photo with a flash, and the flash washes out the
foreground subjects, you can move the Highlights slider to the left to darken the
washed-out areas of the image. You can use the Highlights slider in conjunction
with the Shadows and Midtones sliders to balance the lighting.
Shadows slider — lets you adjust the brightness in the darkest areas of an image.
For example, a bright light behind a photo subject (backlighting) at the time a
photo is taken can cause the subject to appear in shadow. You can correct the photo
by moving the Shadow slider to the right to lighten the dark areas and reveal more
detail. You can use the Shadows slider in conjunction with the Highlights and
Midtones slider — lets you adjust the brightness of the midrange tones in an
image. After adjusting the highlights and shadows, you can use the Midtones
slider to fine-tune the image.
The Highlights and Shadows sliders can lighten or darken specific areas of an image.
The histogram lets you view the tonal range of an image to evaluate and adjust the color and tone. For example, a histogram can help you detect hidden detail in a photo that is too dark because of underexposure (a photo taken with insufficient light).
The histogram plots the brightness values of the pixels in an image on a scale of 0 (dark) to 255 (light). The left part of the histogram represents the shadows, the middle part represents the midtones, and the right part represents the highlights. The height of the spikes indicates how many pixels are at each brightness level. For example, a higher number of pixels on the left side of the histogram indicates the presence of image detail in the dark areas of the image.
The photo on the left is underexposed. Right: The histogram indicates a large amount of image detail in the dark areas of the photo.
The tools in the Image Adjustment Lab let you view images in various ways, so that you can evaluate the color and tone adjustments you make. For example, you can rotate images, pan to a new area, zoom in or out, and choose how to display the corrected image in the preview window.
Although the Image Adjustment Lab lets you correct the color and tone of most images, a specialized adjustment filter is sometimes required. Using the powerful adjustment filters in the application, you can make precise adjustments to images. For example, you can adjust images by using a tone curve. For more information about adjustment filters, see Adjusting color and tone.
To correct color and tone in the Image Adjustment Lab |
1. |
Click Bitmaps Image Adjustment Lab.
2. |
Click Auto adjust.
Auto adjust automatically adjusts color and contrast by setting the white point and black point for an image. |
If you want to control the white point and black point setting more precisely, click the Select white point tool
, and click the lightest area of your image. Then click the Select black point tool
, and click the darkest area of your image. |
3. |
Perform one or more tasks from the following table.
The Image Adjustment Lab is not available for CMYK images. For CMYK
images, you can access the Auto adjust filter and other adjustment filters from
the Effects menu.
You can capture the current version of your image by clicking the Create
snapshot button. Thumbnails of the snapshots appear in a window below your
image. Each snapshot is numbered sequentially and can be deleted by clicking
the Close button in the upper-right corner of the snapshot title bar.
You can undo or redo the last correction you made by clicking the Undo
button
or the Redo button
. To undo all corrections, click the Reset to
original button.
To view images in the Image Adjustment Lab |
1. |
2. |
Perform a task from the following table.
