This section provides a sample of the CGM data that you can apply to objects. It is divided into three parts:
When you choose an action as the type, any of the following can function as
the value:
one or more ActiveCGM commands
BasicScript subroutine name
operating system command
external application
When you choose an event as the type, only one or more Active CGM
commands can function as the value.
button1press
Type: event
Description: Triggers when you click any of the members of the group.
Value: WebCGM_button1press, or any of the WebCGM actions
Constraint: none
content
Type: text
Description: Allows you to declare the first priority when searching the text
content of a ‘para’ APS.
Value: none
Constraint: none
cursorenter
Type: event
Description: Triggers when the pointer moves within two pixels of any of the
Value: WebCGM_cursorenter, or any of the WebCGM actions
Constraint: none
cursorexit
Type: event
Description: Triggers when the pointer moves off all members of the group.
Value: WebCGM_cursorexit, or any of the WebCGM actions.
Constraint: none
hover
Type: event
Description: Triggers when the pointer moves over any member of the group.
Value: any of the WebCGM actions
Constraint: none
linkuri
Type: action
Description: Loads a file in the target window as specified by the URI.
Value: either one or three strings entered by user input
If it is one string, it will represent the URI. Example: “http://www.corel.com”
If it is three strings, the first string is the URI, the second is the empty string,
and the third is the target frame. Example: “http://www.corel.com” “” “_blank”The target frames are as follows:
_blank — viewer loads the content in a new window
_self — viewer loads the content in the same window
_parent — viewer loads the content in the immediate frameset parent
of the active window
_top — viewer loads the content in the full original window
Constraint: none
name
Type: text
Description: Names the group.
Value: entered by user input Example: “Corel Designer Group”
Constraint: none
region
Type: text
Description: Provides an optional spatial region, associated with a graphic object,
allowing the user to pick operations for the object. Simple regions of type rectangle,
ellipse, polygon, and continuous polybezier can be defined.
For a rectangle, two corner points of the viewport are provided, as in (x1,y1)
(x2,y2). Example: -820084 215104 342822 867138
For an ellipse, three points are provided. The first point specifies the center of the
ellipse, while the remaining two points specify the CDP points, as in (x1,y1)
(x2,y2) (x3,y3). Example: -275602 514233 -786474 514233 -275602 282324
For a polygon, points are provided where n is the number of vertices in the
polygon using the formula n*(x.y).
For a polybezier, points are provided where n is the number of contiguous cubic
segments using the formula 3n+1(x,y). Example (polybezier with three vertices): 235270 712532 -235270
712532 342822 87386 342822 87386 342822 87386 -235270
87386 -235270 87386 -235270 87386 -235270 712532 -
235270 712532
Value: none
Constraint: none
screentip
Type: text
Description: Causes the value to be displayed as a screen-tip when the pointer is
positioned over the group.
Value: entered by user input as a single string that is associated with a graphic
object or a group Example: “This is a screentip”
Constraint: none
viewcontext
Type: number
Description: Lets you specify the initial view of an object when you position the
pointer over the graphic object that contains this attribute.
The value of the viewcontext specifies the two corner points of the viewport rectangle as (x1,y1) (x2,y2), where x1, y1 is the top-right point of the viewport rectangle and x2, y2 is the bottom-left point of the viewport rectangle. Example: -925688030 586990613 -799207691 509452731 |
Constraint: none
WebCGM_button1press
Type: action
Description: Erases all usertip message boxes in the target window. Example: ‘eraseusertip;execute -extension “linkuri”’
Value: eraseusertip;execute -ext
Constraint: none
WebCGM_cursorenter
Type: action
Description: Displays the specified usertip. Example: ‘displayusertip -tip “<This is a screentip>”’
Value: displayusertip -tip
Constraint: none
WebCGM_cursorexit
Type: action
Value: eraseusertip
Constraint: none
@ML_button1press
Type: event
Description: Makes the group visible.
Value: @ML_ToVisible
Constraint: none
@ML_button1release
Type: event
Description: Makes the group invisible.
Value: @ML_ToInvisible
Constraint: none
@ML_cursorenter
Type: event
Description: Changes the group color to red.
Value: @ML_ToRed
Constraint: none
@ML_cursorexit
Type: event
Description: Changes the group color to its original color.
Value: @ML_ToNative
Constraint: none
@ML_ToInvisible
Type: action
Value: changegroup -vis off
Constraint: fixed
@ML_ToNative
Type: action
Value: changegroup -co native
Constraint: fixed
@ML_ToRed
Type: action
Value: changegroup -co red
Constraint: fixed
@ML_ToVisible
Type: action
Value: changegroup -vis on
Constraint: fixed
button1press
Type: event
Value: PressButton1, or any of the WebCGM or ActiveCGM actions
Constraint: none
button1release
Type: event
Description: Triggers when you release the left mouse button while the pointer is
positioned over any of the members of the group.
Value: ReleaseButton1, or any of the WebCGM or ActiveCGM actions
Constraint: none
cursorenter
Type: event
Value: ToRed, or any of the WebCGM or ActiveCGM actions
Constraint: none
cursorexit
Type: event
Value: ToNative, or any of the WebCGM or ActiveCGM actions
Constraint: none
description
Type: text
Description: This behavior is undefined.
Value: entered by user input Example: “product description”
Constraint: fixed
desc
Type: text
Constraint: fixed
linkuri
Type: action
Constraint: none
region
Type: text
235270 712532
screentip
Type: text
Constraint: none
viewcontext
Type: number
Constraint: none
