Lenses change how the object area beneath the lens appears, not the actual properties and attributes of the objects. You can apply lenses to any vector object, such as a rectangle, ellipse, closed path, or polygon. You can also change the appearance of artistic text and bitmaps. When you apply a lens over a vector object, the lens itself becomes a vector image. Likewise, if the lens is placed over a bitmap, the lens also becomes a bitmap.
After you apply a lens, you can copy it and use it with another object.
The following are the types of lenses that you can apply to objects.
To apply a lens |
1. |
Select an object.
2. |
Click Effects Lens.
3. |
Choose a lens type from the list box in the Lens docker.
4. |
Specify the settings you want.
You can preview the different types of lenses in real time without auto-
applying them to a drawing by clicking the Lock button and then choosing a
lens and settings to preview. When you find the lens you want to use, click
Apply, or click the Lock button again to resume auto-applying the lenses
while previewing them.
To copy a lens |
1. |
Select the object to which you want to copy the lens.
2. |
Click Effects Copy effect Lens from.
3. |
Click the object from which you want to copy the lens.
