Corel DESIGNER lets you apply a variety of preset brushstrokes, ranging from brushstrokes with arrowheads to brushstrokes that are filled with patterns. When you draw a preset brushstroke, you can specify some of its attributes. For example, you can change the width of a brushstroke and specify its smoothness.
You can also create custom brushstrokes by using an object or a group of vector objects. When you create a custom brushstroke, you can save it as a preset.
| To apply a preset brushstroke |
1. |
Click the Linear pattern tools button, and click the Linear pattern brush
tool
2. |
Choose a brush category from the Category list box on the property bar.
3. |
Choose a brushstroke from the Brushstroke list box on the property bar.
4. |
Drag until the stroke is the shape you want.
If you have access to a brushstroke that is not listed in the Brushstroke list
box, you can apply it by clicking the Browse button on the property bar, and
locating the brushstroke file.
| To create a custom brushstroke |
1. |
Select an object or a set of grouped objects.
2. |
tool
3. |
Click the object or grouped objects.
4. |
Click the Save linear pattern stroke button
5. |
Type a filename for the brushstroke.
6. |
Click Save.
Example of a custom linear pattern brushstroke
You can also create custom brushstrokes by clicking Window |
