For each new layer that you create, the display, editing, and printing and exporting properties are enabled by default. You can change these properties at any time. You can also turn a local layer into a master layer, or a master layer into a local layer. For information about master layers, see Creating layers.
The icons to the left of a layer’s name let you change the layer’s properties.
You can choose to show or hide layers in a drawing. Hiding a layer lets you identify and edit the objects on other layers. It also reduces the time required for your drawing to refresh when you edit it.
You can set printing and exporting properties for a layer to control whether a layer is displayed in the printed or exported drawing. Note that hidden layers are displayed in the final output if the printing and exporting properties are enabled. The Document grid layer cannot be printed or exported.
You can allow editing of the objects on all layers or restrict editing so that you can only edit objects on the active layer. You can also lock a layer to prevent accidental changes to the objects it contains. When you lock a layer, you cannot select or edit the objects on that layer.
You can rename layers to indicate their contents, their position in the stacking order, or their relationship with other layers.
You can change the layer color so that objects on the layer are displayed with the layer color when you use Wireframe view. For example, if you place various components of an architectural plan (plumbing, electrical, structural) on separate layers, you can use layer color to quickly identify to which component the objects belong.
To change layer properties |
1. |
If the Object manager docker is not open, click Window Object manager.
2. |
Right-click the layer, and click Properties.
3. |
Specify the settings you want.
To show or hide a layer |
1. |
2. |
Click the Show or hide icon
beside the layer name.
The layer is hidden when the Show or hide icon is grayed out. |
Objects on a hidden layer are displayed in the printed or exported drawing
unless the layer’s printing and exporting properties are disabled.
You can also show or hide a layer by right-clicking the layer in the Object
manager docker and then clicking Visible.
To enable or disable printing and exporting of a layer |
1. |
2. |
Click the Enable or disable printing and exporting icon
beside the layer
name.
Disabling the printing and exporting of a layer prevents its contents from
appearing in the printed or exported drawing, or in full-screen previews. For
information about full-screen previews, see Previewing drawings.
You can also enable or disable the printing and exporting of a layer by right-
clicking the layer in the Object manager docker and clicking Printable.
To set the editing properties of a layer |
1. |
2. |
In the Object manager docker, click the name of the layer that you want to edit.
The layer name appears in a red bold font to indicate that the layer is active. |
3. |
Perform a task from the following table.
If you disable editing across layers, you can work only on the active layer and
the Desktop layer. You cannot select or edit objects on inactive layers. For
example, if you use the Pick tool to marquee-select multiple objects on the
drawing page, only the objects on the active layer are selected.
You cannot lock or unlock the Document grid layer.
You can also allow editing on all layers by clicking the Edit across layers
button
in the Object manager docker. Editing across layers is enabled
when the button appears pressed. Clicking the button again restricts editing to
the active layer.
You can also lock or unlock a layer by right-clicking the layer in the Object
manager docker and then clicking Editable.
To rename a layer |
1. |
2. |
Right-click the layer name, and click Rename.
You can also rename a layer by clicking the layer name twice and typing a new
name.
To change the layer color |
In the Object manager docker, double-click the color swatch that appears to the
left of the layer name, and choose a color.
Objects on the layer are displayed with the layer color when you use Wireframe view (View Wireframe). |
You can also choose to display only the objects on a specific layer in Wireframe
view by right-clicking the layer name, choosing Properties, and enabling the
Override full color view check box in the layer properties dialog box.
