Corel DESIGNER provides you with several ways to copy objects. When you no longer need an object, you can delete it.
You can cut or copy an object to place it on the Clipboard and paste it into a drawing or another application. Cutting an object places it on the Clipboard and removes it from the drawing. Copying an object places it on the Clipboard but keeps the original in the drawing.
Duplicating an object places a copy directly in the drawing window and does not use the Clipboard. Duplicating is faster than copying and pasting. Also, when duplicating an object, you can specify the distance between the duplicate and the original object along the x and y axes. This distance is known as the offset.
Duplicate offset
You can create multiple copies of objects simultaneously, while specifying their position, without using the Clipboard. For example, you can distribute object copies horizontally, to the left or right of the original object; or you can distribute copies of objects vertically, below or above the original object. You can specify the spacing between copies of objects, or you can specify the offset at which copies of objects are created in relation to each other.
| To cut or copy an object |
1. |
Select an object.
2. |
Click Edit, and click one of the following:
Cut
Copy
You can also cut or copy an object by right-clicking the object and clicking Cut
or Copy.
| To paste an object into a drawing |
Click Edit |
| To duplicate an object |
1. |
Select an object.
2. |
Click Edit |
The duplicate is placed at an offset from the original object. |
When you duplicate objects for the first time, the Duplicate offset dialog box appears. To specify the distance between the duplicate and the original object along the x and y axes, type values in the Horizontal offset and Vertical offset boxes. |
Offset values of 0 place the duplicate on top of the original.
Positive offset values place the duplicate up and to the right of the original.
Negative offset values place the duplicate down and to the left of the original.
If you’ve set the Ctrl and Shift keys to the Windows standard
(Ctrl=Duplicate/Leave original, Shift=Constrain), you can duplicate an
object as you place the duplicate where you want in the drawing window. To
do this, first select the object using the Pick tool
You can also duplicate a selected object by pressing Ctrl + D.
You can change the offset at which duplicates are created. Click Tools |
| To delete an object |
1. |
Select an object.
2. |
Click Edit |
You can also delete an object by clicking the object and pressing Delete.
| To create copies of an object at a specified position |
1. |
Select an object.
2. |
Click Edit |
3. |
In the Step and repeat docker, type a value in the Number of copies box.
Multiple copies of an object are offset by a specified distance.
