You can copy object properties such as outline, fill, and text properties from one object to another. You can copy object transformations such as sizing, rotating, and positioning as well as effects applied to an object.
| To copy object properties from one object to another |
1. |
Click the Eyedropper tools button, and click the Attributes eyedropper tool
2. |
Click Properties on the property bar, and enable any of the following check boxes:
Outline
Fill
Text
3. |
Click the edge of the object whose properties you want to copy.
The Attributes eyedropper tool automatically switches to the Apply object attributes mode. |
4. |
Click the edge of the object to which you want to apply the copied properties.
Any Transformations and Effects options on the property bar that are
enabled are also applied when you copy properties.
You can also copy fill or outline properties, or both, by right-clicking an object
with the Pick tool
You can also copy object properties to a selected object by clicking Edit |
| To copy size, position, or rotation from one object to another |
1. |
2. |
Click Transformations on the property bar, and enable any of the following check
boxes:
Size
Rotation
Position
3. |
Click the edge of the object whose transformations you want to copy.
4. |
Click the edge of the object to which you want to apply the copied transformations.
Any Properties and Effects options on the property bar that are enabled are
| To copy effects from one object to another |
1. |
2. |
Click Effects on the property bar, and enable any of the following check boxes:
Perspective
Envelope
Blend
Extrude
Contour
Lens
PowerClip
Drop shadow
Distortion
3. |
Click the edge of the object whose effects you want to copy.
4. |
Click the edge of the object to which you want to apply the copied effects.
Any Properties and Transformations options on the property bar that are
