Application commands are accessible through the menu bar, toolbars, toolbox, property bar, and dockers. The property bar and dockers provide access to commands that relate to the active tool or current task. The property bar, dockers, toolbars, and toolbox can be opened, closed, and moved around your screen at any time.
You can customize many of these workspace elements to suit your needs. For more information, see Customizing Corel DESIGNER.
Standard toolbar | ![]() |
The standard toolbar contains buttons that are shortcuts to many of the menu commands.
The standard toolbar is displayed by default. For information about customizing the position, contents, and appearance of toolbars, see Customizing toolbars.
More about toolbars | ![]() |
In addition to the standard toolbar, Corel DESIGNER has toolbars for specific kinds of tasks. For example, the Text toolbar contains commands relevant to using the Text tool. If you use a toolbar frequently, you can display it in the workspace at all times.
The table below describes toolbars other than the standard toolbar.
Exploring the toolbox | ![]() |
The Corel DESIGNER toolbox shows the active tool and the available categories of tools in the upper area. The options symbol
indicates that there are additional tools or options.
When you choose a tool, any additional tools or options appear in the options area at the bottom of the toolbox. When you choose a tool in the options area, it becomes the active tool.
For example, if you click the Curve tools button in the upper area, you see its associated tools in the options area. If you click the 2-point line tool in the options area, it becomes the active tool, and its icon appears on the Curve tools button in the upper area.
You can use flyout menus instead of the options area. Click Tools ![]() |
The following table provides descriptions of the tools in the Corel DESIGNER toolbox.
Property bar | ![]() |
The property bar displays the most commonly used functions that are relevant to the active tool or to the task you’re performing. The property bar content changes depending on the tool or task. For example, when you click the Text tool in the toolbox, the property bar displays only text-related commands, such as text, formatting, alignment, and editing tools.
You can customize the contents and position of the property bar to suit your needs. For more information, see Customizing the property bar.
Dockers | ![]() |
Dockers display the same type of controls as a dialog box, such as command buttons, options, and list boxes. Unlike most dialog boxes, you can keep dockers open while working on a document, so you can readily access the commands to experiment with different effects.
An example is the Property manager docker. When this docker is open, you can click an object in the drawing window and view formatting, dimensions, and other properties of the object.
Dockers can be either docked or floating. Docking a docker attaches it to the edge of the application window. Undocking a docker detaches it from other parts of the workspace, so it can be easily moved around. You can also collapse dockers to save screen space.
Status bar | ![]() |
The status bar displays information about selected objects, such as width and height, cursor position, and relevant commands. While you are drawing a non-freehand line or curve, the segment length and total length for all segments are displayed. It also displays document color information, such as the document color profile and color proofing status.
See Customizing the status bar for information about customizing the contents and appearance of the status bar.
The graphic shows some of the information displayed in a status bar.
