When you convert paragraph text to Web-compatible text, you can edit the text of the published document in an HTML editor. If you are exporting text to HTML, you can change text font characteristics, including the font type, size, and style. The Web-compatible text sizes, numbered 1 through 7, correspond to particular point sizes between the 10-point and 48-point range. For more information about formatting text, see Formatting text.
The default Web font style is used automatically unless you override it with another font. If you choose to override it, the default font is used when visitors to your Web site don’t have the same font installed on their computers. The bold, italic, and underline text styles are also available. You can apply uniform fills, but not outlines, to Web-compatible text.
Any non-Web-compatible text in your drawing is converted to bitmaps when you publish your drawing to the World Wide Web as HTML.
| To make text Web-compatible |
Artistic text cannot be converted to Web-compatible text and is always treated
as a bitmap. However, you can convert it to paragraph text and then make it
Web compatible. For information on converting text, see Finding, editing, and
converting text.
