You can create color styles from the colors of an existing object or from scratch. When you create a color style, the new color style is saved to the active document and to the Color styles palette.
After you create a color style, you can apply it to objects in the document. Corel DESIGNER lets you access available color styles through various controls: the Color styles docker, the Object styles docker, the Property manager docker, the Color styles palette, and the Document palette. (A color style is automatically added to the Document palette when you apply it to an object.)
Color styles can be combined into groups called harmonies. A harmony allows you to link color styles into hue-based relationships and modify them together as a set. By editing color styles in a harmony, you can quickly create a variety of alternate color schemes by shifting the colors together, or you can alter the color composition of your artwork in one step.
Corel DESIGNER allows you to create a special type of color harmony called a gradient. A gradient consists of a master color style and a number of shades of that color style. For most of the available color models and palettes, the derivative color styles share the same hue as the master color style but have different saturation and brightness levels. With the PANTONE MATCHING SYSTEM and Custom spot color palettes, the master color style and the derivative color styles are linked to one another but have different tint levels.
You can create a harmony from the colors of an existing object or from scratch.
Corel DESIGNER also lets you select all color styles that are not used in the document or merge unwanted color styles into others. It also lets you convert color styles to different color modes or to spot colors to prepare your document for production printing.
To create a color style or harmony from a selected object |
1. |
Select an object by using the Pick tool
2. |
Click Window Color styles.
3. |
In the Color styles docker, click the New color style button
, and choose New
from selected.
4. |
In the Create color styles dialog box, enable one of the following options in the
Create color styles from area:
Object fill — creates a color style from the color of the object fill
Object outline — creates a color style from the color of the object outline
Both fill and outline — creates color styles from the object fill and outline
colors
5. |
To group the new color styles based on hues of similar saturation and value, enable
the Group color styles into harmonies check box, and specify the number of
harmonies in the box.
If you want to convert the color styles to a different color mode, enable the
Convert all color styles to check box, and choose a color mode from the list
box.
You can also create color styles or color harmonies from a selected object by
using any of the following methods:
Drag the selected object to the top part of the gray area in the Color
styles docker to create independent color styles, or drag the selected
object to the bottom part of the gray area to create color styles grouped
into harmonies. Then, specify the settings you want in the Create
color styles dialog box.
Right-click the object in the document window, and choose Color
styles New from Selected. Then, specify the settings you want in
the Create color styles dialog box.
Click the arrow button on the Color styles palette, and choose Add
from selection.
To create a color style |
1. |
2. |
Drag a swatch from any open palette to the top part of the gray area in the Color
styles docker.
If you want to create color styles from all the colors in your document, do one
of the following:
, and
choose New from document.
In the document window, right-click an object using the Pick tool
and choose Color styles New from document.
On the Color styles palette, click the arrow button
and choose Add
from Document.
You can also create a color style by clicking the New color style button
choosing New color style, and choosing a color in the Color editor. The
Color editor provides a variety of options to choose the right color:
Eyedropper tool, color viewers, sliders, and palettes. For more information
about choosing colors, see Working with color.
To create a color harmony |
1. |
2. |
In the Color styles docker, click the New color harmony button
, and choose
New color harmony.
A folder icon for the color harmony appears in the bottom part of the gray area. |
3. |
Drag any color swatches or color style swatches to the harmony folder.
You can also duplicate a harmony by selecting its folder in the Color styles
docker, clicking the New color harmony button
, and choosing Duplicate
harmony.
You can resize the Color harmonies area so that you can view available color
harmonies without scrolling by pointing to the grab area, and when the cursor
changes to a two-directional arrow, dragging the edge of the pane.
To create a gradient |
1. |
2. |
In the Color styles docker, select a color style as the master color for the gradient.
3. |
Click the New color harmony button
, and choose New gradient.
4. |
In the New gradient dialog box, specify the number of shades in the Number of
colors box.
5. |
Adjust the Shade similarity slider.
Move the slider to the left to create very different shades; move the slider to the right to create very similar shades. |
6. |
Enable one of the following options:
Lighter shades — creates shades that are lighter than the master color
Darker shades — creates shades that are darker than the master color
Both — creates an equal number of light and dark shades
To apply a color style |
1. |
2. |
3. |
In the Color styles docker, do one of the following:
Double-click a color style to apply a fill.
Right-click a color style to apply an outline.
You can also apply a color style to a selected object by using any of the
following methods:
On the Color styles palette or the Document palette, click a color
style to apply a fill or right-click a color style to apply an outline. To
open the Color styles palette, click Window Color palettes Color
styles palette.
Drag a color style from a palette or the Color styles docker to the
object.
In the Outline or Fill section of the Property manager docker, click
the source indicator next to the color picker, and choose from the list of
previously created color styles.
You can also use the Object styles docker to apply a color style, if the
object style that is assigned to an object contains a color attribute, such
as a fill or outline. In the style properties area of the Object styles
docker, click the source indicator next to a color picker, and choose
from the list of previously saved color styles.
