You can associate a number of different file types with Corel applications. When you double-click a file you have associated with an application, the application starts and the file opens. When you no longer need a file type association, you can break it.
To associate a file type with Corel DESIGNER | ![]() |
1. |
Click Tools ![]() |
2. |
In the list of categories, double-click Global, and click Filters.
3. |
Click Associate.
4. |
In the Associated file extensions with Corel DESIGNER list, enable the check
box of the file type you want to associate.
(Windows 7 and Windows 8) Associating a file type with an application adds
the application to the list of recommended programs for opening this file type.
To open a file of an associated file type in Corel DESIGNER while browsing in
Windows, you also need to make Corel DESIGNER the default program. To
do this, click the Start button on the Windows taskbar, and then click Default
programs. Next, click Associate a file type or protocol with a program. For
detailed instructions about how to change the default program for a file type,
see the Windows Help.
You can reset file associations by clicking Reset.
To break a Corel DESIGNER file type association | ![]() |
1. |
Click Tools ![]() |
2. |
3. |
Click Associate.
4. |
In the Associated file extensions with Corel DESIGNER list, disable the check
box of the file type association you want break.
