You can draw a grid and set the number of rows and columns. A grid is a grouped set of rectangles that you can break apart.
To draw a grid |
1. |
In the toolbox, click the Rectangle tools button, and click the Graph paper tool
2. |
Type values in the Columns and rows box
on the property bar.
3. |
Drag diagonally to draw the grid.
If you want to draw the grid from its center point outward, hold down Shift as
you drag. If you want to draw a square grid, hold down Ctrl as you drag; if the
grid has an equal number of rows and columns, the cells will be square as well.
To ungroup a grid |
1. |
Select a grid by using the Pick tool
2. |
Click Arrange Ungroup.
