You can make styles and style sets available for use in other documents by exporting them to a Corel DESIGNER style sheet (.cdss) file. A style sheet contains all the object styles, style sets, color styles, and default object properties in the active document. You can also use styles and style sets from other documents by importing the style sheet to which they were saved.
| To export a style sheet |
1. |
Click Window |
2. |
In the Object styles docker, click the Import, export, or save defaults
button
3. |
In the Export style sheet dialog box, choose the folder where you want to save the
style sheet.
4. |
Type a file name in the File name box.
5. |
Click Export.
6. |
Enable the check boxes for the settings you’d like to export from the document.
| To import a style sheet |
1. |
Click Window |
2. |
button
3. |
In the Import style sheet dialog box, choose the folder where the style sheet is
stored.
4. |
Select the file name, and click Import.
5. |
Enable the check boxes for the settings you’d like to import into the document.
You can also import styles and style sets from an existing Corel DESIGNER
file by selecting the file in the Import style sheet dialog box and clicking
Import.
