When publishing a document or selection to the World Wide Web, you can choose several options, such as image format, HTML layout, export range, and file transfer protocol (FTP) site parameters.
| To export to HTML |
1. |
Click File |
2. |
Set the following options in the Export HTML dialog box:
Details — contains details of HTML files produced, and allows you to change
the page name and file name
Advanced — provides options for generating JavaScript for rollovers and
cascading style sheets, and maintaining links to external files
Summary — shows statistics for files according to various download speeds
Issues — displays a list of potential issues, including explanations, suggestions,
and tips
Corel DESIGNER assigns the extension .htm to documents you publish in the
HTML format. By default, HTML files share the same name as the
Corel DESIGNER (DES) source file and are saved in the last folder you used to
store exported Web documents.
