With Corel DESIGNER, you can create mirror images of objects. Mirroring an object flips it from left to right or top to bottom. By default, the anchor point is in the center of the object.
| To mirror an object |
1. |
Select an object.
2. |
Click Arrange |
3. |
In the Transformations docker, enable the Mirror horizontally option
4. |
In the Transformations docker, click the point on the origin locator
To leave the original object unchanged and apply the transformation to a copy, type 1 in the Copies box in the Transformations docker. |
5. |
Click Apply.
You can also mirror a selected object by holding down Ctrl and dragging a
selection handle to the opposite side of the object.
