Asian character input is only supported in Corel DESIGNER when using an Asian operating system or when language support is installed on a non-Asian operating system. You can choose a default font and text orientation (either horizontal or vertical) when typing text. When you type artistic or paragraph text, the program uses a default artistic or paragraph text style.
| To choose a default font for Asian text |
1. |
Click the Text tool
2. |
Press Esc to ensure that no objects are selected.
3. |
Choose an input method from the Input Method Editor (IME) on the Windows
status bar.
If the Windows Language bar is displayed, you can choose an input method from the Language bar. |
4. |
Choose a font from the Font list box on the property bar.
5. |
Choose a font style from the Font style list box.
| To choose a text orientation for Asian text |
1. |
Using the Pick tool
2. |
Click Window |
3. |
In the Property manager docker, click the Frame button
4. |
Choose one of the following orientation options from the Text orientation list box:
Horizontal
Vertical
The default orientation for Asian text is horizontal.
When you change the text orientation from horizontal to vertical, underlines
become left lines and overlines become right lines.
The text orientation setting applies to the entire text object. You cannot have
text with different orientations in one text object.
If you have Asian text support installed with your operating system, you can
also change text orientation by clicking the Vertical text orientation
