Hyphenation can be used to break a word if the entire word does not fit at the end of a line. You can hyphenate automatically by using a preset hyphenation definition in combination with your own hyphenation settings. You can set the minimum number of characters before and after a hyphen. You can also specify the number of characters in the “hot zone,” which is the area at the end of a line where hyphenation can occur.
You can insert an optional hyphen in a word to produce a specific word break at the end of a line. You can also create custom definitions that specify the location of optional hyphens in specific words whenever you type, paste, or import the words in the application.
| To hyphenate paragraph text automatically |
1. |
Using the Text tool
If the Property manager docker is not open, click Window |
2. |
In the Property manager docker, click the Paragraph button
3. |
In the Paragraph area of the Property manager docker, click the arrow button
4. |
Enable the Hyphenation check box.
5. |
Click the Hyphenation settings button.
6. |
In the Hyphenation settings dialog box, enable the Automatically hyphenate
paragraph text check box.
Hyphenation can be used for any languages that have corresponding writing
tools installed with the application. For more information about language
modules, see Working with languages.
If you do not see any hyphenated words in the paragraph after applying
hyphenation, you may need to modify the hyphenation settings.
| To modify the hyphenation settings |
1. |
Using the Text tool
2. |
3. |
4. |
With the Hyphenation check box enabled, click the Hyphenation settings
button.
5. |
In the Hyphenation settings dialog box, perform one or more tasks from the
following table.
To
Do the following
Hyphenate capitalized words
Enable the Break capitalized words check box.
Hyphenate words that contain all uppercase letters
Enable the Break words using ALL CAPS check box.
Set a minimum word length for automatic hyphenation
In the Hyphenation criteria area, type a value in the Minimum word length box.
This value represents the minimum number of characters that hyphenated words must contain.
Set the minimum number of characters to precede a hyphen
In the Hyphenation criteria area, type a value in the Minimum characters before box.
Set the minimum number of characters to follow a hyphen
In the Hyphenation criteria area, type a value in the Minimum characters after box.
Set the “hot zone”
In the Hyphenation criteria area, type a value in the Distance from right margin box. This value represents the number of characters in the hot zone. A word that does not fit within this zone is hyphenated or moved to the next line.
| To insert an optional hyphen |
1. |
Using the Text tool
2. |
Click Text |
You can insert an optional hyphen by pressing Ctrl + -.
| To create a custom definition for optional hyphenation |
1. |
Click Text |
2. |
In the Word box, type the word for which you want to create the hyphenation
definition.
When you type in the Word box, the same text is entered in the Hyphenated word box. |
3. |
In the Hyphenated word box, click where you want the optional hyphen inserted,
and press the Hyphen key (-).
4. |
Click Add definition.
The custom hyphenation definition is defined only for the language specified
in the Language list box. You can choose another language without affecting
your keyboard.
You can create a custom optional hyphen definition by selecting a word in the
document. The word appears in the Word box of the Custom optional
hyphens dialog box. After you insert the optional hyphen in the Hyphenated
word box, you can apply it by clicking Apply to selection.
You can find and replace optional hyphens. For more information, see To find
text and To find and replace text.
