You can insert and view 3D models in Corel DESIGNER by using the embedded interface of XVL Player, a 3D viewer for XVL files. In addition, you can use the controls of the XVL player to adjust the view of the 3D model by panning, rotating, zooming, and choosing a different view.
Inserted 3D models are linked with the source 3D files. Any adjustments that you make to an inserted file affect the source file. You can break the link between the inserted files and the source 3D files at any time.
| To insert a 3D model |
1. |
Click File |
If this menu command is not available, you must update your installation to include XVL Player. For more information, see To modify or repair a CorelDRAW Technical Suite installation. |
2. |
Locate and open the XVL file that you want to insert.
3. |
Drag in the drawing window to insert the file at the desired size and position.
You can insert only 3D models saved to the XVL file format. To insert a 3D
model saved to another file format, you must first import it (File |
| To adjust the view of a 3D model |
1. |
Double-click the graphic in the drawing window.
2. |
Using the controls in the XVL player, do any of the following:
Pan the 3D model.
Rotate the 3D model.
Zoom in and out of the 3D model.
Change the view.
To adjust the view of a 3D model, you can also right-click the graphic in the
drawing window, and click Edit 3D model.
| To break the link between an inserted 3D model and its source file |
1. |
Using the Pick tool, select the inserted graphic.
2. |
Click Window |
3. |
In the Links and bookmarks docker, click the Break link button
