You can insert and delete the rows and columns in a table.
To insert a table row |
1. |
Select a row in the table.
2. |
Perform a task from the following table.
When you use either the Row above command or the Row below command
from the Table Insert menu, the number of rows that are inserted depends
on how many rows you have selected. For example, if you have selected two
rows, then two rows are inserted in the table.
To insert a table column |
1. |
Select a column.
2. |
When you use the Column left command or the Column right command
from the Table Insert menu, the number of columns that are inserted
depends on how many columns you have selected. For example, if you have
selected two columns, then two columns are inserted in the table.
To delete a row or column from a table |
1. |
Select the row or column that you want to delete.
2. |
If you select a row but choose the option to delete a column, or if you select a
column but choose the option to delete a row, the whole table is deleted.
