To ensure color accuracy, a color management system needs ICC-compliant profiles for monitors, input devices, external monitors, output devices, and documents.
Monitor color profiles — define the color space that is used by your monitor to
display document colors. Corel DESIGNER uses the primary monitor profile that
is assigned by the operating system. The monitor profile is very important for color
accuracy. For more information, see Is my monitor displaying the correct colors?.
Input device color profiles — used by input devices such as scanners and digital
cameras. These color profiles define which colors can be captured by specific input
devices.
Display color profiles — include monitor profiles that are not associated with your
monitor in the operating system. These color profiles are especially useful for soft-
proofing documents for monitors that are not connected to your computer.
Output device color profiles — define the color space of output devices such as
desktop printers and printing presses. The color management system uses these
profiles to map accurately document colors to the colors of the output device.
Document color profiles — define the RGB, CMYK, and grayscale colors of a
document. Documents that contain color profiles are known as “tagged.”
Many color profiles are installed with your application or can be generated with profiling software. Manufacturers of monitors, scanners, digital cameras, and printers also provide color profiles. In addition, you can access color profiles from Web sites such as:
http://www.color.org/findprofile.xalter — This Web site of the International Color
Consortium (ICC) can help you find commonly used standard color profiles.
http://www.eci.org/doku.php?id=en:downloads — This Web site of the European
Color Initiative (ECI) provides standard ISO profiles as well as profiles that are
specific to Europe
http://www.tftcentral.co.uk/articles/icc_profiles.htm — This Web site provides
ICC profiles for many different types of LCD (Liquid Crystal Display) monitors to
help you display consistent colors. However, if color accuracy is essential for your
workflow, you should calibrate and profile your monitor instead of relying on
readily available monitor profiles. For more information, see Is my monitor
If you don’t have the necessary color profile, you can install it, or you can load it within the application. Installing a color profile adds it to the Color folder of the operating system; loading a color profile adds it to the Color folder of the application. CorelDRAW Graphics Suite can access color profiles from both Color folders.
When you save or export a document to a file format that supports color profiles, the color profiles are embedded in the file by default. Embedding a color profile attaches the color profile to the document to ensure that the same colors you used are shared with anyone who views or prints the document.
To install a color profile |
In Windows Explorer, right-click a color profile, and click Install profile.
To load a color profile |
1. |
Click Tools Color management Default settings.
2. |
In the Default color setting area, choose Load color profiles from the RGB,
CMYK, or Grayscale list boxes.
3. |
In the Open dialog box, navigate to the color profile.
After you load a color profile, you can also access it from the Color proof
settings docker, Print dialog box, and Document color setting dialog box.
Note that you can load a color profile of any color mode from any list box:
RGB, CMYK, or Grayscale. However, after you load the profile, you can
access it only from the list box of the respective color mode. For example, you
can load an RGB color profile from the CMYK list box, but you can access the
profile only from the RGB list box.
You can also load a color profile from the Document color settings dialog
box.
To embed a color profile |
1. |
Click File, and then click one of the following commands:
Save as
Export
Export for Web
2. |
In the dialog box that appears, enable the Embed color profiles check box.
When you save or export a file to the Corel DESIGNER (DES) or Adobe
Portable Document Format (PDF) file format, you can embed up to three color
profiles.
Embedding a color profile increases the file size of a document. To avoid
increasing the file size unnecessarily, Corel DESIGNER embeds only color
profiles for colors that are used in the document. For example, if your
document contains only RGB objects, only the RGB color profile will be
embedded.
