You can lay out a print job by specifying the size, position, and scale. Tiling a print job prints portions of each page on separate sheets of paper that you can assemble into one sheet. You would, for example, tile a print job that is larger than your printer paper.
| To specify the size and position of a print job |
1. |
Click File |
2. |
Click the Layout tab.
3. |
In the Image position and size area, enable one of the following options:
As in document — maintains the image size as it is in the document
Fit to page — sizes and positions the print job to fit to a printed page
Reposition images to — lets you reposition the print job by choosing a position
from the list box
Enabling the Reposition images to option lets you specify size, position, and
scale in the corresponding boxes.
You can also choose an imposition layout, such as 2 x 2 (4-up) or 2 x 3 (6-
up), from the Imposition layout list box. For more information, see Working
with imposition layouts.
| To tile a print job |
1. |
Click File |
2. |
3. |
In the Image position and size area, enable the Print tiled pages check box.
4. |
Type values in the following boxes:
Tile overlap — lets you specify the amount by which to overlap tiles
% of page width — lets you specify the percentage of the page width the tiles
will occupy
You can include tiling alignment marks by enabling the Tiling marks check
box.
