Open Prepress Interface (OPI) lets you use low-resolution images as placeholders for the high-resolution images that appear in your final work. When a print service provider receives your file, the OPI server substitutes the high-resolution images for the low-resolution placeholders.
To maintain OPI links |
1. |
Click File Print.
2. |
Click the PostScript tab.
3. |
Enable the Maintain OPI links check box.
The Maintain OPI links option is available for PostScript devices only.
You can reduce your work time by using OPI and print management server
solutions, such as Creo Color Central. Low-resolution samples are
automatically created from the high-resolution originals and are placed in
Corel DESIGNER. These files contain their own OPI comments, which the
Creo Color Central server recognizes when it receives the job and then
substitutes the high-resolution version of the file for the low-resolution version.
Low-resolution images must be flagged as OPI images (this must be done
using third-party software) before you can import them into a document.
