The default object properties in Corel DESIGNER control the appearance of text and graphic objects in the active document. For example, when you install Corel DESIGNER for the first time, the default properties for graphic objects determine that each new graphic object has a black outline and no fill.
You can modify the default properties of the following types of objects: artistic media, artistic text, callout, dimension, graphic, and paragraph text. When you modify the defaults, Corel DESIGNER automatically saves these changes to the current document. If you want to use the custom settings in subsequent documents that you create, you can set them as the new document defaults.
You can specify which object styles, style sets, color styles, or default object properties in the active drawing are set as the new document defaults.
| To edit default object properties |
1. |
Click Window |
2. |
In the Object styles docker, open the Default object properties folder, and
choose one of the following object types:
Artistic Media
Artistic text
Callout
Dimension
Graphic
Paragraph text
3. |
Modify the attributes you want.
Any changes you make are applied to all new objects in the active document and are automatically saved with the document. |
You can also edit the default object properties while editing any object in the
document window. Right-click the Default object properties folder in the
Objects styles docker, and choose Update default properties when editing
objects. Any change you make to an object becomes the default setting for
new objects.
| To set the current style settings as the new document defaults |
1. |
Click Window |
2. |
In the Object styles docker, click the Import, export, or save defaults
button
3. |
Enable the check boxes for the settings that you’d like to save as the default
settings for new documents.
You can also save settings as the default settings for new documents by using
the Options dialog box. For more information, see Saving defaults.
